Hi everyone,
I have a 1989 toyota camry sv21 wagon auto, done about 320,000kms on its second engine, and has so far proven to be very reliable, and apart from leaking in the car when raining I would say i'm very happy with this as a first car. Toyota knows what they're doing when they make cars.
But just today the transmission stopped working, details are as follows:
When starting in neutral: all is well, but when changing through any of the gears (R, D, 1, 2) there is a griding sound but the gears will not engage. And when shifted to park, a very bad grinding sound happens.
When starting in park (P): there is no grinding sound until shifting through the gears, then if put back into park, a very bad grinding sound happens again.
Also, when put into gear, my speedometer will show that I am doing whatever I would be doing if the car was actually moving.
This happened suddenly not gradually.
My initial guess was that the gearbox was at fault, but I think it may be the transaxle or differential as a speed is still displayed (I'm not sure at which stage the sensor is located).
Apologies for rambling, just wanted to provide enough information.
My question is what part will need to be replaced and at what approximate cost please?
I intend to invest in a haynes repair manual and do the work myself if the engine doesn't have to be removed.
Cheers
