Hard brakes when cold - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-04-2010, 08:19 AM   #1 (permalink)
View midnightrunner's Photo Gallery
Hello,
Whenever it is cold out, my 91 camry will sometimes have a stiff brake pedal which I will have to pump several times to stop the car. It only happens at a cold start such as when backing out of the drive way in the morning or after work. The brakes will function if I pump them. I tried searching the forum but came up empty. I have read on subura and nissan forums about the brake booster check valve getting moisture in it and freezing. Is this the same problem; has anybody fixed this on the Camry?
Thanks
midnightrunner is offline   Reply With Quote
Old 12-04-2010, 07:10 PM   #2 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
Usually this can be caused by ice on the brake rotors, frozen rear brakes and too much water in the brake fluid.
Doctor J is offline   Reply With Quote
Old 12-04-2010, 09:48 PM   #3 (permalink)
Gameroom cash: $285600
View '88 All-Trac's Photo Gallery
If you aren't much of a mechanic, I would take it somewhere and have them flush the brakes. It sounds like fluid in the lines or, as mentioned, frozen calipers.
The brakes on our Jeep have frozen down a few times as well.
'88 All-Trac is offline   Reply With Quote
