Can't get new rear strut mounts in? 1990 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-04-2010, 05:01 PM   #1 (permalink)
Gameroom cash: $121520
View karbonfyber's Photo Gallery
I am trying to replace the strut mounts on my 1990 camry sedan. However, both the moog and monroe strut mounts are a bit off, one of the screws is like off by 0.5mm. http://www.kyb.com/products/struts/i...ount_large.jpg using that as an example it would be the closet screw that is 0.5mm off. Anyone have any suggestions or is it just difficult to get in? I'm thinking about enlarging the mounting hole a bit...
karbonfyber is online now   Reply With Quote
Old 12-05-2010, 02:26 PM   #2 (permalink)
Gen2 King
91 Camry's Avatar
Gameroom cash: $161755
View 91 Camry's Photo Gallery
when i mounted my intrax springs and KYB struts i had to make the holes a little bigger to fit the new mounting plates. use a dremel.
~~~~GEN-2 Camry~~~~
Running the Streets Since 1986
91 Camry is offline   Reply With Quote
Old 12-05-2010, 02:29 PM   #3 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Gameroom cash: $609731
View Zembonez's Photo Gallery
Won't harm a thing by enlarging the mounting hole.
Go for it!
Zembonez is offline   Reply With Quote
Old 12-05-2010, 09:20 PM   #4 (permalink)
What about alignment? will that mess with the alignment in anyway?
Old 12-05-2010, 09:21 PM   #5 (permalink)
Gen2 King
91 Camry's Avatar
no it will not
~~~~GEN-2 Camry~~~~
Old 12-05-2010, 09:32 PM   #6 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Originally Posted by 91 Camry View Post
no it will not
I agree. You'd be hard pressed to see a difference on a good alignment machine. I'm willing to bet your suspension parts are deformed more than that from just being used. They all do that.
Old 12-16-2010, 10:08 PM   #7 (permalink)
View 89Camry89's Photo Gallery
I had a lot of trouble with the rear right strut mount on my '89. From the sound of it, the trouble was very similar to what you describe. I could get any two but not all three stabbed through the holes. Eventually I forced it through there without hurting the threads.
The other 3 mounts were fine.
89Camry89 is offline   Reply With Quote
Old 12-16-2010, 10:28 PM   #8 (permalink)
Heh I had to shave it a bit but I got it in, probably will take the nut off and put a nice thick washer under the nut due to the enlarged hole
Old 12-17-2010, 01:36 PM   #9 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
Those nuts are there to hold the strut from falling out only under full extension - don't even worry about it. The only want there could possibly be a problem is if you are jumping the car...
-Charlie
