Originally Posted by stanno
Ok, so blow by may cause the pulsating at idle. If it were blow by, would that pulsation still be present when rpm is increased ?
Reason i asked is cuz when i do increase rpm, the pulsation subsides, but, i don't really feel any vacuum.
I'm wondering now if this is the cause of the misfiring in my engine. With the engine idling, i can hear puffing from the tailpipe and sometimes i can hear the engine making popping noises at idle also... suggesting a misfire
I think you are confusing some terms or something...
If you pull the crankcase vent tube off while the engine is running, you are supposed to feel air puffing/pulsing out. It vents to the intake manifold to keep emissions down and keep the engine 'closed' so the AFM meters air correctly. There will never be vacuum coming from the engine side, and there should always be vacuum on the intake manifold side.
The pulsing subsides at higher RPM because the indivual pulses are too closely spaced to feel (each combustion event makes a pulse).
"Puffing" out the tail pipe at idle is normal. The little pops do suggest that there is a misfire, but that is separate from anything else.
-Charlie
