control arm bushings - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-14-2010, 12:05 AM   #1 (permalink)
View Lee250's Photo Gallery
Gen1 control arm bushings
i need to change my lower control arm bushings on my car. There are 2 different bushings. The one from the sway bar to the control arm and the control arm to the body. I found a set with both bushings in it for about $40. anybody know of anywhere that is cheaper?
1986 camry dlx
1986 Camry 2.0 Not going to let it die currently 228,000 miles.
1999 Camry 2.2
1986 tercel wagon 2wd - sold
Lee250 is offline   Reply With Quote
Old 12-14-2010, 12:16 AM   #2 (permalink)
Gameroom cash: $121520
View karbonfyber's Photo Gallery
I am doing the same thing right now, replacing my lower control arm bushings, However , I have found a brand new LCA for 60 dollars with ball joint so I am getting that instead of wasting time replacing the bushings. Try rockauto
karbonfyber is online now   Reply With Quote
Old 12-16-2010, 07:54 AM   #3 (permalink)
View joeykrim's Photo Gallery
i replaced mine with poly urethane bushings but i also have the fat sway bars from whiteline.
i think i got them from a parts place in michigan. its been about 4 yrs. they work great! good luck!
Current: 1990 Toyota Camry DX - Intrax Springs (2001), KYB GR2 Struts (2001 front and rear, 2009 rear warranty replaced), Erebuni Bodykit(front uninstalled, side skirts installed), custom cold air intake with K&N filter, very nice stereo and car alarm.
http://car.joeyconway.com
joeykrim is offline   Reply With Quote
Old 12-16-2010, 10:17 PM   #4 (permalink)
View 89Camry89's Photo Gallery
A price of $40 sounds fairly good to me.
However, if I were in your shoes I would consider replacing the control arms. The reason is that for similar or a little more money you may find a control arm that already has these bushings installed.
I can attest that it takes some work to remove the bushing where the sway bar goes through. I've heard rumors that the other one is pressed in but I don't know that for sure.
Before you purchase a control arm with bushings, you may want to consider a control arm with bushings *and* with a new ball joint already installed on it. (Again for a few more dollars, of course.)
Technically, it would be less of your labor to swap in the new arm since you'd do the arm and be done. Otherwise it takes a lot of screwing around to get those bushings out. I spent close to an hour to get one of the control arm bushings completely out of there.
Take your old control arms to the junkyard and get $5 for the scrap metal. Use that to buy a sub sandwich.
89Camry89 is offline   Reply With Quote
Old 12-16-2010, 10:30 PM   #5 (permalink)
I just bought 2 new control arms with ball joints, good brand from rockauto for 60 a piece, IMO its much easier to swap out the whole thing than replacing the bushings and ball joints as the ball joint was 20 alone and 20 for the bushings, I rather spend the extra 20 dollars and save a few hours.
Old 12-17-2010, 01:28 AM   #6 (permalink)
Gameroom cash: $150200
View 66conv6's Photo Gallery
I purchased bushings from the Toyota dealer but had to pay $25 to have a machine shop press them in.
66conv6 is online now   Reply With Quote
Old 12-22-2010, 12:40 PM   #7 (permalink)
rock auto does not sell 1st gen control arms. thats why I was going with just the bushings. I have acces to a full shop with presses and lifts and everything so not a big deal.
1999 Camry 2.2
Old 12-25-2010, 02:22 PM   #8 (permalink)
Staying on the Road
View Eugee's Photo Gallery
Does anyone know the best way to remove the bushing where the stabilizer meets the control arm without removing the control arm ? Any special tools that would help. I have an 86 that I'm trying to get road worthy on a very tight budget. Thanks for any suggestions; Eugee
Eugee is offline   Reply With Quote
