Cold until Warm… Auto transmission slips problem/question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-14-2010, 03:22 PM   #1 (permalink)
Gameroom cash: $128800
View Sturdavj's Photo Gallery
Question Cold until Warm… Auto transmission slips problem/question
1990 Camry LE 4cyl, auto/OD
When I got the car a couple weeks ago the transmission was slipping. When I would first start off, when I placed it in gear and attempted to move, forward/reverse there was a slip …20sec before it engaged. This also happened when I would leave from a stop (light/sign), It would slip until (15-20sec…) it would engaged and then move through gears with no apparent problems, until next stop.
I adjusted the kick down cable and the problem went away. Now the slipping at first start up has returned, for the most part the starting / stopping while underway is working OK.
The fluid level is where it needs to be, but is dark so I plan to change filter & replace drained fluid, adding Lucas Trans medic at same time. Is there anything I should look for with the pan removed?
I picked up in one of the posts that this might be a possible pressure issue, and with the pan off be sure to check the ??? valve, I don’t remember the name and/or function of this valve? Sorry I went through
Sturdavj is offline   Reply With Quote
Old 12-14-2010, 06:06 PM   #2 (permalink)
Gameroom cash: $812801
View zythr's Photo Gallery
When you say dark, do you mean black? If so, that means the bands in the tranny are wearing, which means a rebuilt/new tranny.
zythr is offline   Reply With Quote
Old 12-16-2010, 07:45 PM   #3 (permalink)
Finally had some time tonight to drain the transmission fluid and it is the color of graphite, black with silver/gray streaks…… which is probably not a good thing.
I'll go ahead and pull the pan, clean pan & replace filter, put in new fluid as well some Lucas trans treatment and see where it goes
Old 12-17-2010, 06:05 PM   #4 (permalink)
Unfortunately sounds like you're going to need a new/used tranny.
Old 12-17-2010, 09:22 PM   #5 (permalink)
Yea, I had better start shopping...
