Speedo Calibration or gear change? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-24-2010, 10:22 AM   #1 (permalink)
View Tatohead's Photo Gallery
2nd Generation Speedo Calibration or gear change?
I swapped in a tach cluster to my base model 5-speed 90. Love having the tach. However, the speedometer reads about 5% too high.
I know a lot of people perform this swap; is there a solution? The speedo drive gear is bolted externally and presumably can be removed/swapped. Is the auto trans version a different ratio?
Or, is the difference in the final drive ratio (differential) of the auto vs manual? This would obviously be a much bigger problem to solve.
THANKS
Tatohead is offline   Reply With Quote
Old 12-24-2010, 10:32 AM   #2 (permalink)
Oops, one quick question I didn't think of... Is the gearing difference neither in the speedometer drive gear nor the diff? Is the correct gearing a function of the speedo itself? In other word, should I have swapped the speedo unit from the old cluster? I'm not trying to preserve the indicated mileage so it wasn't an issue at the time....
thanks
Old 12-24-2010, 10:38 AM   #3 (permalink)
Tech1984's Avatar
Gameroom cash: $254350
View Tech1984's Photo Gallery
SINCE YOU HAVE IT ON HAND, i WOULD START BY SWAPPING BACK JUST THE ORIGINAL SPEEDO HEAD.
Bin wrenchin' on the Yota's since '84
2000 Tundra SR5 4.7 Ex Cab
2010 Camry LE 2.5
Cheers!
Tech1984 is offline   Reply With Quote
Old 12-27-2010, 01:09 PM   #4 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
The speedo drive is the same for all the different transmission options on the gen2 Camry. If the speedo reads wrong, it is a problem with the speedo itself, generally. Swap just the speedo section of the cluster back to your original.
-Charlie
