I don't remember if they used this on the first generation Camry (1983-1986), but the other generations actually had an alternator fuse. It acts as a main fuse for many of the car's functions. If I remember correctly, when this fuse blows only things like the emergency flashers will work (and maybe the headlights). Check the owner's manual for if, if that is still available. Many times you have to unbolt the fuse box in the engine compartment and lift it up to change this fuse. It usually is held in by an 8MM hex head bolt that has to be removed from the side, hence having to unbolt the fuse box itself and lift it. THis large fuse runs $3-$4 at places like Autozone. It runs about $20 at a Toyota dealer. Just be sure to disconnect the negative battery cable first.
Mike
