I would avoid going older with the transmission. It will probably fit, but the age might be an issue. The older they are, the more likely there will be problems (weak synchros, etc.).
Any 2wd transmission from an '87-'01 4-cylinder Camry and '87-'99 Celica GT or GTS. The Celica transmissions have shorter gearing thatn the Camry transmissions, but are externally compatible (you can swap out the electronic speedo for your mechanical speedo if you get a newer one).
-Charlie
