The high beam indicator light on the dash lights up through the low beam filament of your headlight bulbs. If there is no bulb there (in your case, probably a relay or other higher resistance thing), then the light either will not light up or will be very dim when the high beams are on.
Otherwise, take those HIDs off your car. You are blinding and annoying other drivers.
-Charlie
