New Developments
ok, finally got down to doing what i should have started with, i checked the trouble codes and i was getting 4-1 and 5-1. checked throttle sensor and it was physically broken, either from my friend who put it in or the mechanic who did some "work" on it. put the old one back in now i only get 5-1. First, are the codes the same for a corolla as for a camry? i am going by a corolla manual (cant find my camry manual), which lists 5-1 being for 1988 and later, and that 5-1 being "a/c switch signal". could someone clarify this please? anyways, it still wont start, and it floods. that diagnosis is "a/c switch on, idle switch off during diagnosis check", then for trouble area: a/c switch circuit; a/c switch; a/c amplifier; throttle position sensor circuit; throttle position sensor; ECU. since in my camry manual all the codes go by 1-1, 2-2, 3-3 and so on, i am going by the 88 and later codes.
so before, when it ran, if you accidently hit the "econ" button, the car would act as if it was going to die. could the 5-1 code be related to that? what can i look for for that diagnosis and trouble area? i unplugged the 3 a/c related fuses (in engine compartment) to no avail. how else can i disconnect the entire a/c system? might the throttle sensor need adjustment? cuz the screw slots make it so it can be adjusted. how likely is it that the throttle sensor would quit working? the spring part works fine and the elec. tabs are good. sorry for all the ?'s. any help would be nice, as i cant afford to play engine part russian roulette any more. thanks.
