Control arm bushing DIY potential interest - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-12-2011, 09:11 PM   #1 (permalink)
View scarney1988's Photo Gallery
I replaced the lower control arm bushing, where the sway bar passes through, on my 1990 Camry LE 4 cylinder sedan. My drivers side was totally shot. I will be doing the passenger side within a week or two. I can take pictures explaining the process if anyone is interested. If no one responds responds ill assume I'm the only idiot replacing bushings lol I know a lot of people just replace the whole lower arm. It was fairly straight forward.
Steps I followed:
  1. remove tire of side to be replaced.
  2. Remove cotter pin of ball joint castle nut, seperate ball joint from lower control arm
  3. using 22mm socket and a breaker bar, loosen up nut on the end of the sway bar and the other nut that holds the control arm to the vehicle
  4. Remove two bolts and two nuts that hold the subframe brace and control arm stud bracket to car
  5. Finesse parts around and remove lower arm
  6. Use air hammer and chissel point to drive out one side, then the other (not to bad actually). Takes a few tries to get the metal lip bent out a little to use that as a hammering point
  7. I used a shop press to install the new bushings, however I feel like using a vice, clamp, or even a hammer and a block of wood could be used in a pinch
scarney1988 is offline   Reply With Quote
Old 01-13-2011, 09:12 AM   #2 (permalink)
View hzt30's Photo Gallery
I will be doing my bushings (1991 Camry) this spring so I would be interested in the process and pictures.
hzt30 is offline   Reply With Quote
Old 01-13-2011, 09:32 AM   #3 (permalink)
Gameroom cash: $128800
View Sturdavj's Photo Gallery
I'll be right behind you with mine, any info would be helpful
Thanks
Sturdavj is offline   Reply With Quote
Old 01-13-2011, 04:39 PM   #4 (permalink)
View bugman987's Photo Gallery
yep there is actual interest, not just potential interest. Pics are always helpful.
bugman987 is offline   Reply With Quote
Old 01-13-2011, 06:22 PM   #5 (permalink)
[QUOTE=scarney1988;3443518]I replaced the lower control arm bushing, where the sway bar passes through, on my 1990 Camry LE 4 cylinder sedan. My drivers side was totally shot. I will be doing the passenger side within a week or two. I can take pictures explaining the process if anyone is interested.
You had better get started, I have just started ordereding my suspension parts
Old 01-16-2011, 03:15 PM   #6 (permalink)
View Kingdom934's Photo Gallery
I've heard stories where people burned their old bushings out of the control arm...
I'd would buy a new arm + bushings, but no one sells it with the arm and bushing for the Gen1. I gotta do mines too, so gaaaaa. I just am dreading getting the old bushing out of the control arm
'85 Camry DLX 158K
'87 Cressida 78K
'07 Nissan Versa 63K SD (traded in)
'10 Nissan Versa 26K HB (traded in)
'04 Camry XLE V6 52
Kingdom934 is offline   Reply With Quote
Old 01-16-2011, 03:48 PM   #7 (permalink)
I got the bushings from rockauto.com
I took pictures as I went. I just need some quiet time to write it up. Not hard to do. Air compressor and air hammer recommended (I used a husky cheapy from home depot). If you have a vice I would imagine a chisel and minisledge hammer could be used. Would take some elbow grease, but seems possible.
