91 camry 2.0 dx. Got another question different but also the same as my other thread. ive replaced fuel filter,cold air intake,ignition coil, distributor o ring,plugs,rotor,cap,wires,motor and trans mounts,cleaned some filter from the pod next to the egr. (couldnt get the banjo bolt from egr to clean it). ran lots of fuel injector cleaner and got them cleaned at the shop on car(not very well). throttle bodys cleaned also. intake its 100% sealed.
a couple new vaccum hoses but still most of them are in rough shape but only one has a very tiny crack in it.
also spent 130 on a tps that wasnt needed.
i occasionaly get a stutter/bog on acceleration and then it smooths out by high reving and drives fine the rest of the way (doesnt stall).
Rough idle also randomly.and harsh engagement into first sometimes.
im all out of ideas. the car was ran on 3 cylinders for a long time. no leaks though. 1,and number 2 injectors are covered in sludge (other 2 very little) rail is covered and even the windshield wiper motor and passanger side strut tower is covered. so what ever it is its shotting up pretty well.
pressed throttle and watched injectors no spraying or anything i seen.
should i put all new gaskets on injectors or spend big bucks on injectors?
or buy a new distributor sence its the only ignition part that hasnt been replaced.
the stuttering its like a misfire type of stutter.
Money pit. i love the car but im running out of patience and ideas
anyone?
