the other night i was manually shifting out my 89 camry. stupid i guess. just wanted to see what she would do
. i disengaged the overdrive button on the shifter, pulled the shifter down into low and took off approximately 3/4 throttle and shifted out into 2nd and then into third.....i was give or take at about 100 mph and decided that was enough and let off the gas and re-engaged the overdrive button. i soon relized that over drive was not there. the o/d off light went out on the dash when i re-engaged it like normal but i also noticed that the tranny normal and power shift ligt wasn't on either! then i relized that all at the same time my blower motor was'nt working, seat belts were stuck in the forward position after getting back in the car and the gas hand appears to be not working. it shows the amount of gas that was in it after everything stopped working. cause the next day i put $15 in it and it didn't move.
is there a fuse or something that could have blown or what?
