Ive replaced all of my ignition components except the distributor.which i cleaned with electrical cleaner very well.
Every so often the car will drop in rpms and sort of bog under acceleration.
i replaced most vaccum lines. seemed to help a teeny bit. adjusted timing (retard slightly) helped slightly.
car also starts slowly if its really cold and then runs rough for about 30 secs- 1 min . could that be distributor related? or battery related?
dont want to replace dizzy if i dont have too of course (no multimeter, need to get one
). family mechanic says the car wouldnt run with a bad dizzy.
compression is 200 straight across.
alternater was replaced withen the last 2 years.
please shed your 2 cents! -thank you tyler.
