91 camry. ive replaced the whole igntion system except distributor.
all new vacuum hoses. fuel filter, air filter, o2 sensor,oil pressure sensor,valve gaskets. the list goes on and on.
i get an occasional stumble on acceleration, like a bog/dieing out. i push the throttle more or let up and it gets going after about 3 seconds.
on the high way going into 4th i beleive it kinda slightly jerks more that going into any other gears.
if im comming off a turn or a long idle. sometimes first doesnt engage instantly.
and when its cold the car bucks,stumbles and acts very strange for about 5-6 seconds.
where do i even go now? never been stranded.....yet. but these problems bother me and id like to fix them so the car will last.
tranny fluid checked by 2 oil change places and said its good (i put lucas in and fresh fluid in the summer. no filter change)
no leaking trans fluid or oil.
trans is very jerky. and the mount has been replaced. as well as the front motor mount. noticed "sludge" covering the left part of firewall,wiper motor,injectors,fuel rail. and all wires.but car doesnt leak oil
car was ran VERY hardly on 3 cylinders (crack in dis tower) for a while.
and i got it running pretty smooth minus these problems. throttle bodys clean and injectors also. car idles pretty well. i did adjust the throttle cable and distributor timing slightly ( for a little better acceleration) and that helped i beleive.
I know multiple people on here know what could be wrong, very smart.
please please give me a hand. i do the same when i know what im talking about. HELP!
