oil light is on at idle only - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-11-2011, 03:58 PM   #1 (permalink)
88' camry v6 LE's Avatar
View 88' camry v6 LE's Photo Gallery
2nd Generation oil light is on at idle only
My oil light has just started to come on at an idle after it has warmed up. I'm guessing that my oil pump is bad now. any other ideas?
I have also just replaced all cam seals so the car wouldn't leak oil anymore and be wasted. the issue no is that I'm still losing oil some how. I have full engine power and have not notice any smoke coming out of the tail pipe. My car also isn't leaking any oil at all anymore.
as always thanks for the help guys, Jon
88' Camry LE v6 : project car & now my daily driver 190k miles on it now, bought it with 150k... still going strong!!!
96' Integra GSR : 262k miles
08' Odyssey : 40k miles
06' Yamaha R6 : 12k miles
88' camry v6 LE is offline   Reply With Quote
Old 02-11-2011, 04:11 PM   #2 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Gameroom cash: $609731
View Zembonez's Photo Gallery
Wear in main and rod bearings is a major source of oil pressure loss. It's quite possible that the engine is due for a rebuild. I doubt the pump is just croaking, but if a high pressure or HD pump is available for it, it might add enough pressure to bump the idle pressure enough to run a bit longer..
Zembonez is offline   Reply With Quote
Old 02-11-2011, 04:14 PM   #3 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
The oil pump may be bad... but I would be more concerned that you have serious bearing wear. The V6 is known to eat crank and rod bearings, especially at the mileage you are at. Oil burning could be normal blow-by at this age. How much are you losing/burning?
Do you hear any knocking (cluck-clunk sounding) coming from the engine? It will still have full power, or close to it, even with bad bearings (for a while....).
-Charlie
Old 02-11-2011, 04:48 PM   #4 (permalink)
View holmesnmanny's Photo Gallery
Might want to make sure ur oil isn't moving into the cooling system.
1991 Camry LE V6 Automatic
holmesnmanny is offline   Reply With Quote
Old 02-11-2011, 06:50 PM   #5 (permalink)
WhippinCamry's Avatar
View WhippinCamry's Photo Gallery
Is it possible that its a bad or leaky oil pressure sensor?
thats my only thought. could be worth a check. there pretty cheap.
WhippinCamry is offline   Reply With Quote
Old 02-11-2011, 07:22 PM   #6 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
You make a valid point. OP does need to confirm that the indicated oil pressure is in fact correct. Using a temporary mechanical gauge would confirm it.
Old 02-12-2011, 12:21 PM   #7 (permalink)
also check around the valve cover. if youve got a little money to spend. replace the valve cover gasket? its easy to do. make sure your drain plugs tight.
i would check simple things first.
