[QUOTE=Doctor J;3478290]Just saw this post by the accident.
part of that procedure is described on K. Sullivan's Autoshop 101, automatic transaxle articles (pictures toward the end of articles)
Thanks for the site info, I booked mark it.
I have been involved with bearing pre-loads on larger gearboxes. Then had the shims machined. This work was carried out on an engine stand. This was on transit trains, twins to the ones that run through Sacramento. I understand what your say about loading the differential from the RH side, makes since.
This tranny has some slip in it (cold fluid). What I think I’ll do is replace the bearing and shim, put it back together run it and see what develops….
