Outer door handle removal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-13-2011, 03:58 PM   #1 (permalink)
Gameroom cash: $285600
View '88 All-Trac's Photo Gallery
2nd Generation Outer door handle removal
I've been fighting with this damn thing for a good 20 minutes. How do you remove the pushrod for the door latch from the outer door handle without destroying the little plastic clip? I don't have any spares and the nearest parts house is 50 miles away.
Am I just screwed? Will I need to wait until the next time I'm in town to get a replacement clip?
'88 All-Trac is offline   Reply With Quote
Old 02-14-2011, 02:33 PM   #2 (permalink)
View clkinaz's Photo Gallery
You should be able to pivot the clip out of the way such that it allows the rod to slip out. But, unfortunately, they don't always survive the movement. In any event, I've reassembles more than one door without complete clips and everything seems to have held in place well enough.
clk
clkinaz is offline   Reply With Quote
Old 02-14-2011, 04:00 PM   #3 (permalink)
Yeah, the pivoting part was easy enough... However, it seems as though there is a captive "ball" on the pushrod, which is held in place by the clip where it is run through the hole. I don't want to break the clip because I have no idea where to get a replacement.
Old 02-14-2011, 04:59 PM   #4 (permalink)
View nopain00's Photo Gallery
If you do break the clip, there are a bunch available here: https://www.clipsandfasteners.com/Se...neBy_Price=7-9 . I believe the front door ones are p/n 69293-12060 for LH, and the same with 50 at the end for RH.
nopain00 is offline   Reply With Quote
The Following User Says Thank You to nopain00 For This Useful Post:
'88 All-Trac (02-14-2011)
Old 02-14-2011, 10:20 PM   #5 (permalink)
Sweet! Thanks a bunch!
Old 02-15-2011, 07:53 PM   #6 (permalink)
View Tatohead's Photo Gallery
Thanks for posting the link on those clips. I recently fixed a door handle and NOBODY in town had the part. NAPA offered to order it in for like $18. Several parts stores sold "variety packs", but none fitted.
I ended up just pulling one from a junkyard car. These all eventually break. If you take the door panel off, take the opportunity to grease up the window mechanism.
Good luck.
Tatohead is offline   Reply With Quote
