Originally Posted by stanno
Cool!
Ok, for the axle bracket. Is there "tested proven" fab that works, i was thinking maybe getting both the bracket from the 4 & 6 banger and trying to combine 'em with some cutting/welding? Would that work?
Yeah, since you will only be putting 155hp through the clutch, a 5s-fe/3s-fe clutch would probably be fine, now that you mention it. They guys that use the custom clutch are pushing 250hp+, generally.
There is not tested proven way. I dont' know anybody who has yet done what you are looking to do... I just know it works because the exact opposite way works (4-cyl with the v6 trans). The brackets are both cast iron, so you plan might be difficult. You will probably want to get both brackets and start with some measurements. You might be able to get away with some drilling and mild machining to get it to work. If I remember right, the holes are like 1/2" off or so...
-Charlie
