1990 Camry head - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-19-2011, 10:06 AM   #1 (permalink)
View ZEDOB's Photo Gallery
2nd Generation 1990 Camry head
Hi,
I bought a 1990 Camry a few months ago and ended up having to change out the head gasket. I bought a head from a refurbishing company and ran into a bit of a twist. The head is not quite the same. I know I need to contact the seller, but it's the weekend and they're not open and I just want to get an idea of what I do have. Hopefully I can get these pictures to load up.
the picture below is of the old head. Notice the depth of the injector holes. They are only about 10mm deep.
Notice how deep the injector holes are in the next photo. They are also about 1mm too large in diameter. There is also a vent hole, or somthing like that running through the head casting and tying the injector holes together. You can see it at the top of the injector hole.
There is also a hose barb that seems to be for PCV because it is connected to the oil drain passage and is shielded from splatter. Not worried about that. Just figured it help in identification.
Everything else fits fine and the casting looks almost identical except for these differences. It was advertised as the head for a 1990 3sfe, but is there a possibility that what I got was from a California car? If so can I get new injectors that fit and if so will they fit up to the fuel rail?
Here are some side views to help anyone in the know who might be able to identify this head.
Like I said, I'll be calling the seller back, but I'd like to have my guns loaded so I don't sound like a dumb-arse.
Any help would be appreciated. Thanks again.
Russ
ZEDOB is offline   Reply With Quote
Old 02-21-2011, 11:27 AM   #2 (permalink)
Little update here
I called the supplier (Odessa Cylinder Head out of Clearwater, FL, they're on eBay) and they said that I must have gotten a RAV4 head instead of the 3sfe head. They're sending me a new one. Great customer service. Some light at the end of the tunnel for this project.
BTW, if you are contemplating a head gasket replacement it can be done with the engine still in the compartment. It's just a serious beotch. I think for everything you need to remove there are 3 other things that are in the way. The permutations of part removal is impressive. It's almost like a puzzle.
Old 02-21-2011, 09:47 PM   #3 (permalink)
Gameroom cash: $150200
View 66conv6's Photo Gallery
lol. Memories. I feel your pain. Hang in there.
66conv6 is offline   Reply With Quote
Old 02-22-2011, 06:25 AM   #4 (permalink)
Yeah fun. I think I'm going to start with the right rear turn signal the next time I have to work on the engine. That way it'll be out of the way.
