Need some Help - Power Steering - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-20-2011, 02:05 PM   #1 (permalink)
Gameroom cash: $163200
View Grego 92's Photo Gallery
I'm assembling back my engine after changing the headgaskets. I removed this entire adjusting bracket and I can't find the picture I thought I had took (maybe I didn't) that would show me how to put this back on.
I don't think I have it on right as it doesn't seem to adjust the tension correctly on the power steering belt. Can someone take a picture of theirs and post it or give me a little guidance. thanks.
Greg
Grego 92 is offline   Reply With Quote
Old 02-20-2011, 02:17 PM   #2 (permalink)
Gameroom cash: $128800
View Sturdavj's Photo Gallery
Question
Sorry not at home to take pic’s.
A question(2) I have,
1. Is the belt(s) in the correct position, not crossed up ?
2. Is there more than one belt tensor on your motor, if so are they in the correct location/ component?
Sturdavj is offline   Reply With Quote
Old 02-20-2011, 03:04 PM   #3 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $279892
View csaxon's Photo Gallery
The top of the bracket should be behind the tab instead of in front of it. ( Top Bolt)
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 02-20-2011, 04:42 PM   #4 (permalink)
It's not twisted or crossed. You might be right, there may be another bolt on the steering pump that I don't have in or lined up correctly.
You think the bracket should be behind the motor mount thing?
This is a 90' Camry v6 2VZ-FE..........should have put that to begin with
Old 02-20-2011, 11:59 PM   #5 (permalink)
Thanks, but I figured it out. There was a pivot type bolt I took off from the top portion of the power steering pump that I didn't replace so it was just hanging really low so I didn't get enough tension.
That black/white pic must be from an odd angle or another engine because I tried to put it behind the engine mount bracket thing and it was all ****-eyed and unable to use one of the bolts in that manner.
