Okay friends and fellow camry lovers here is my situation:
I have a '90 3S-FE in pretty good shape, (140-160k miles on it) or at least it was until Christmas Eve of '10. I was driving north to visit some family and the left front quarterpanel came loose from its bolts underneath the vehicle. It had been damaged 2 years prior in a hit & run at of all places, a junkyard!
Due to me not noticing the flapping & scraping sound it bent upwards a bit and cut into my driver's side front tire and the protective covering that was supposed to protect my wiring above said tire had long fallen off. My tire blew up and took some wires with it. Namely two white wires 1 fat one and & 1 thinner one which feed power to the rest of the vehicle. It blew up my 80Amp fusible link, and a few other things (my rheostat and my alternator).
So fast forward just over a month. I've replaced the connector & reconnected the wires managing to get all my lights working again but the following DO NOT work:
Rear Defogger
Turn signals
Wipers & Washer fluid
Radio
Blower Motor
A/C
Cruise control (switch & setting bar)
Fuel & Temp Gauges on my dash
Clock
Most of my indicator lights on my dash
The normal starting process (i.e. you turn the key & the car starts) due to that the guys who originally repaired my car put in a starter switch which is just a wire running to my starter & then to the battery with a nice push button switch stuck in next to the rheostat control in the middle
The automatic seat belts-they don't move
The shift lock mechanism that lets you shift gears. To shift from park I have to hold the shift lock override down & then shift it
The cigarette lighter
The O/D, ECT switch, as well as the nice gear indicator lights on the bottom right of the dash (says P,R,N,D, and O/D status etc)
Also my battery will not recharge.
Other fun factoids:
1.) I have replaced the following:
- The initial connector that was attached to the wires under the left side (driver's side) kick panel under the dash. It is a BLACK connector with 3 wires, 1 THICK white one, 1 Thinner white one, and 1 Medium thickness white one with a nice red stripe. Yes I KNOW these are the main power leads for the vehicle, starting/ignition system, switch etc etc. I repaired the wires by stripping away enough to expose the wiring and then joining them with a wire nut and copious amounts of electrical tape.
- The alternator
- The rheostat-which got my interior (dash & climate control area) lights back on
- Ignition switch
- Engine fuse block box with all attendant relays-entire box good from a junkyard
- Obviously the 80Amp fusible link
2.) ALL THE FUSES ARE FINE. I have checked & rechecked EVERY SINGLE ONE. With the exception of the Hazard-Horn fuse in the engine fuse box which continually blows out.
Yes yes I know my problem sounds exactly like
89 camry/no overdrive,blower,shift indicator lights,etc. but again ALL MY FUSES ARE INTACT
3.) I have an aftermarket radio that I installed myself 6 months after buying the car and it has a nice red blinking light when the faceplate is removed that still blinks telling me it IS still getting power.
4.) The actual TEMPERATURE CONTROL DOES work, just NOT the fan nor the A/C. But it's the end of February and where I live it ain't exactly warm.
5.) Final note here I was driving along nearly 2 weeks ago the day after I lost my job due to not being able to get to & from work (due to the battery dying from not recharging) and sitting at a red light cursing everything I could think of when I noticed my clock was back on. So then I tried my climate control fans (blower motor) and it was working. Same for the A/C. Drove along and then it turned off again. 2-3 minutes later it all comes back again. I try my turn signals. They work. I notice my fuel & temp gauges are moving properly. I quickly slap on my radio's faceplate & it lights up and gives me untuned static. Then everything goes OFF again. 2 minutes later again everything comes back to life. I try my wipers. They work. My cigarette lighter (used to power my phone charger) works. I open my door and the automatic seat belt works. Actually gets stuck in the "forward" position as everything "cycles" OFF again. Another minute later ON again and the seatbelt moves back into place. Finally every time it "cycled" I SWEAR I heard a "clicking" sound from somewhere in the vehicle. Almost like when you re-trip a breaker in your home circuit breaker after the power has gone out.
I have the Factory Service Manuals (All of them) in PDF format from a nice site which is now defunct created by a poster here. So any directions y'all give me I can follow and I have been staring at the Electrical Wiring Diagrams one since I returned and started work on the vehicle the week after Christmas.
Any help would be appreciated. Or in short.......where the h#ll am I losing power at and/or why is it not flowing?!
