need for speeeeeeeeeeeed - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-01-2011, 09:08 PM   #1 (permalink)
WhippinCamry's Avatar
View WhippinCamry's Photo Gallery
USA need for speeeeeeeeeeeed
i know most of you dont approve of driving fast on public streets. but hey it is what it is.
i was just curious what it the top speed youve got your camry too. ive got to about 95. maybe a little more or less.
WhippinCamry is offline   Reply With Quote
Old 03-01-2011, 09:26 PM   #2 (permalink)
dem2757's Avatar
Gameroom cash: $274500
View dem2757's Photo Gallery
85, in its newer days my dad said he got it up to 100 ish
dont wanna give my labored headgasket any more reason to pop for good.
gotta love my v6 though, once that torque converter locks you are moving along pretty well. its no ferrari butttt
dem2757 is offline   Reply With Quote
Old 03-01-2011, 10:19 PM   #3 (permalink)
Gameroom cash: $285600
View '88 All-Trac's Photo Gallery
Bounced it off the governer at 110mph. Twice. This was in my mom's '91 base model. My '88 is geared way wrong to go that fast safely... At least not with 240k miles on the engine.
'88 All-Trac is offline   Reply With Quote
Old 03-01-2011, 11:23 PM   #4 (permalink)
hahaahaha. damn 110. somethings not right with my car then.
mine will just not go past about 90ish usually. even when pushed all the way basically.
Old 03-02-2011, 12:29 AM   #5 (permalink)
Yeah, something is up if it won't do over 90. I have issues keeping it under 85... I do all this and, still coax between 30 and 40 mpg out of it. The all-trac only does 25 mpg... I'm thinking of going more performance with it. Not so much to lose with mileage.
Edit: I apologize for any typos. I'm doing this all on my Galaxy S (Android) device.
Old 03-02-2011, 01:33 PM   #6 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
Most of the gen2 Camrys have a limiter at 180kph (112mph). Some don't though, and I also have a first gen Rev/Speed meter that gets rid to it....
I was able to easily hit the speed limiter in my original 4-cyl 5-speed, my turbo 3s-fe / 3s-gte Camry didn't have a limiter that I found. Once the Alltrac has the new motor, it won't have a limiter because of the Rev/Speed Meter...
This is on a closed circuit racecourse, of course.
-Charlie
PS. I'm scared to find the top speed of my WRX - it should be well north of the original 135mph top speed limiter (removed with an ECU flash).
Old 03-02-2011, 02:03 PM   #7 (permalink)
View nopain00's Photo Gallery
Where's the speed limiter on a gen2? Is it programmed in the ECU?
nopain00 is offline   Reply With Quote
Old 03-02-2011, 02:11 PM   #8 (permalink)
-Charlie
My grandfather took his non-turbo, base-model impreza up to 140, just to see if it would max out the speedo...
Old 03-02-2011, 04:29 PM   #9 (permalink)
white90dx's Avatar
Yup. In the ECU. You can eliminate it with the standard methods by using the wire that comes from the gauge cluster and goes to the ECU. The ECU doesn't care about the actual car speed other than for the speed limiter (and I think later gen2's might throw a code if the wire is cut and left that way for long enough).
-Charlie
Old 03-04-2011, 04:05 AM   #10 (permalink)
View Toyotafan01's Photo Gallery
speedd
I had my 1991 camry about 120 in fourth still had another gear to go. Its a 1991 toyota camry v6 5 speed I was scared to go any faster.
Toyotafan01 is offline   Reply With Quote
Old 03-06-2011, 09:41 AM   #11 (permalink)
Gen2 King
91 Camry's Avatar
Gameroom cash: $161755
View 91 Camry's Photo Gallery
125 in my 4cyl automatic. 5 away from maxing out the speedo.
~~~~GEN-2 Camry~~~~
Running the Streets Since 1986
91 Camry is offline   Reply With Quote
Old 03-06-2011, 10:02 AM   #12 (permalink)
Gameroom cash: $128800
View Sturdavj's Photo Gallery
According to the state trooper 73mph
Sturdavj is offline   Reply With Quote
Old 03-06-2011, 12:11 PM   #13 (permalink)
91 camry. what do u have in yours? there is no possible way its stock.
Old 03-06-2011, 01:20 PM   #14 (permalink)
'86 Camry: 1st Gen
JayLove's Avatar
View JayLove's Photo Gallery
i hit 105mph easily in my SV11.
sometimes i do it on accident.
i've never taken higher
but that's just becuz i dont need anymore tickets.
JayLove is offline   Reply With Quote
Old 03-07-2011, 10:55 AM   #15 (permalink)
View Kingdom934's Photo Gallery
Didn't do too much. It takes wayy too long to get up to speed.
Also I think my speedo is off a bit. I'm running all stock still, so is there a way to get it re-calibrated?
'85 Camry DLX 158K
'87 Cressida 78K
'07 Nissan Versa 63K SD (traded in)
'10 Nissan Versa 26K HB (traded in)
'04 Camry XLE V6 52
Kingdom934 is offline   Reply With Quote
