1992 camry speedometer jumps back and forth - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-03-2011, 12:24 AM   #1 (permalink)
View bmadd's Photo Gallery
Question 1992 camry speedometer jumps back and forth
my 1992 toyota camry's speedometer jumps back and forth, and will not stay steady. what can i do? replace speed sensor? thanks for your help.
bmadd is offline   Reply With Quote
Old 03-03-2011, 10:35 AM   #2 (permalink)
View nopain00's Photo Gallery
92? Should be in the gen3/4 forum.
nopain00 is offline   Reply With Quote
Old 03-03-2011, 12:09 PM   #3 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $279892
View csaxon's Photo Gallery
Check and clean the connectors. Then do a jiggle test of the wires and see if that makes a difference. Pull the speed sensor out and check the plastic gear for wear or broken teeth. The speedometer solder points on the back are known to crack and flex and cause similar symptoms (there was a TSB on it). You could take it out and re touch the solder points with a fresh solder.
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
