Originally Posted by scarney1988
What trim level is your car?
What engine?
Manual or automatic?
Cruise control or not (most important)?
Do you own a multimeter?
Do you own a test light?
I appologize if I got to in depth. I just was not aware of your experience level or tool collection. Stay strong
GOOD LUCK
Hi, Thanks for the reply. No need for apologize, its awesome to get some in depth info.
My camry is a 4 cylinder sv21 automatic with no cruise control.
I do not own a multimeter and test lights. I got no eletrical tools at all.
The brake switch seems to be the cause of the trouble, as I also have to use overwrite to get out of park gear. By messing with the white button on the switch and loosing it then tightening again I got the lights to work for a couple days but now they are out.
I need to replace it I guess. Do the job do I have to release the brake pedal? How do I do that, do I take the spring from the pin or the pin from wherever its going into there?
I mean it was really tough to actually get to the nut on the switch and i'm not sure I can unplug the switch with the pedal on the way.
