Originally Posted by T100_cowboy
you can put it in the oil it acts as a cleaner. I would do it just before you are gonna change the oil and drive it some then change it out. it breaks up gunk but you wanna get it out of the engine after that not net it float around and plug your oi filter.
when you put it in the vacuum line it works best if you have the motor warm first. have someone revving the engine as you add it into the line because yes it will try to die. it will smoke some thats ok. after its all in shut the motor off let it sit 20-30 min. fire it up and take it for a drive and flog it hard. this will help blow all the carbon build-up out.
be warned it will smoke alot on start up and every time you hit the gas for a short time then will stop. its ok your not hurting anything its just the engine burning the sea foam and other stuff.
you'll find you car will probably get better MPG and run sloother and quieter too! It works great I've done this treatment alot on alot of different vehicles
nice, thanks for the info, i can put it in my gas tank as well right? and i have like another 1000 miles before my oil change, would that be too long to let it sit in engine?
