Is it major? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-08-2011, 04:09 PM   #1 (permalink)
AOE
View AOE's Photo Gallery
Is it major?
Ok so I seafoamed my car, and while i was adding it into the brake booster hose, there was smoke coming out of the front of my engine, do i have a leak over there or something? i know its supposed to smoke in the back but the engine also?
AOE is offline   Reply With Quote
Old 03-08-2011, 09:25 PM   #2 (permalink)
View nopain00's Photo Gallery
Just means you have an exhaust leak. It could be through your cat or at the gasket whether it connects to the front pipe. Is there a lot of rust there?
nopain00 is offline   Reply With Quote
Old 03-08-2011, 11:32 PM   #3 (permalink)
AOE
yea im thinkin its an exhaust leak, where can i begin to fix? it comes from the front of the engine and my guess would be a gasket since it is an old car and yea
Old 03-09-2011, 10:09 AM   #4 (permalink)
If you seafoam it again, check to see exactly from where the smoke is coming. It may help to take off the manifold cover. If it's coming out after the cat, then there is a gasket that's probably leaking at the front end of the front pipe.
If it's leaking from the cat itself, it could be rusted through.
Old 03-09-2011, 11:20 PM   #5 (permalink)
Gameroom cash: $285600
View '88 All-Trac's Photo Gallery
My all-trac dumps smoke pretty bad out of the driver's-side-most exhaust manifold runner, or, rather, where it meets up with the block. Is your mani sealed well? I don't care that mine leaks. Better throttle response and I'm just waiting for the engine to die.
'88 All-Trac is offline   Reply With Quote
