Well I got my utility knife and cut the inside door panel. Then used grinder to cut off the sheet metal on inside of door so I could get to the two screws holding the lock solenoid. Hoping that when I disconnected the lock solenoid rod it would just be manual locks on that door. NOT!!!
I still can't open the +^&*ing door!!!
So I guess I will have to buy the additional relay that Toyota said was fix for problem years of 87-90. Mine is a 91 and 2 dealers said mine wasn't covered. I hope the part isn't too much because technically my car is not supposed to be affected and I don't know if this will fix it.
Wonder if Radio Shack would have something similar, probably not.
Well I can take the lock solenoid got at junk yard back.
I am so mad and frustrated!!
