transmission pops out of 5th gear - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-09-2011, 01:09 PM   #1 (permalink)
View metrodriver's Photo Gallery
I finally started driving my 89 with 4 cyl, 5spd manual transmission again after replacing the transmission. It runs like a champ, but it will pop out of 5th gear, all other gears are fine. I assume there needs a little adjustment to be made, but where?
Thanks for the help.
metrodriver is offline   Reply With Quote
Old 03-09-2011, 08:39 PM   #2 (permalink)
A little more info: it seems it is gaspedal position dependent: the more power you give the engine, the stronger the force trying to push the gear shifter out of 5th and into neutral.
It's puzzeling.....
Old 03-10-2011, 06:10 PM   #3 (permalink)
Anybody?
Old 03-11-2011, 12:45 PM   #4 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
Unless there are external linkage issues (check motor mounts, etc), you have a bad transmission.
Popping out of gear generally means worn internals and a need for a full rebuild.
-Charlie
Old 03-11-2011, 01:04 PM   #5 (permalink)
It also seems it doesn't go far enough into the gear. 3rd gear has the same issue (it doesn't pop out, but a little tap on the gear shifter makes it come out). 5th just gets pushed out, and doesn't engage very far. I wonder if I have to adjust the gear selector cable somehow. I just can't find where there are adjustment points, and the manual is not showing anything either.
Old 03-11-2011, 01:21 PM   #6 (permalink)
white90dx's Avatar
Is it harder to pull out of gear while engine braking (instead of being on the gas)?
-Charlie
Old 03-11-2011, 07:03 PM   #7 (permalink)
yes it is. the harder you push the gas, the faster it pops out. I do need to check the rear engine mount
Old 03-11-2011, 07:25 PM   #8 (permalink)
View bovie323i's Photo Gallery
It could be that you have a bad 5th gear shiftfork and the counter shaft bearing could have walked out of place. To fix this, you have to open the case and do a rebuild or source out a good tranny.
bovie323i is offline   Reply With Quote
Old 03-15-2011, 03:52 PM   #9 (permalink)
It (5th gear) pops out real easy when I take the foot of the gas, even by a little bit.
Are the shift cables fixed length or are they adjustable somehow? I would like to see if the gear stays in if I shorten the gear selector cable by half a turn. But how?
Old 03-15-2011, 07:28 PM   #10 (permalink)
white90dx's Avatar
There are no adjustments. All detents, spring action, etc. is handled internally in the transmission.
-Charlie
