Originally Posted by CatLes
When I step on gas pedal engine sounds like it's floating/sputtering. Drained out gas and changed fuel filter what else could it be?
How long has it been since you did any ignition system maintenance? Has it recently been wet, or have you cleaned your engine or driven through a puddle?
You probably have a cracked ignition coil. It is located inside the distributor housing and is known to crack and short internally, causing the problems you describe. If you haven't recently replaced your spark plugs, wires/cap and rotor, those could also be an issue. Use factory ignition components whenever possible - they are MUCH better than anything aftermarket (yes, really).
-Charlie
