Can starting car w/out exhaust connected cause a problem?
My exhaust was disconncected from the manifold and car stalled immediately after starting, now won't start.
Details: 91 3sfe/automatic/US assembled. My exhaust pipe was loose where it comes off the exhaust manifold. I disconncected the pipe and realized the gasket was missing. I left the exhaust disconnected overnight. This morning I tried to start the car to move it and it stalled, then it won't start. It started at least twice yesterday while the exhaust was disconncected. After a few tries to turn over, the battery must have gotten too weak because it stopped trying to turn over. I jumped it and it would turn over, but not start.
Something similar happened to my wife's 98 Accord when the exhaust was disconnected. According to the shop, it ended up needing a new distributor.
It seems like too much of a coincidence for the exact same thing to happen for both cars after disconnecting the exhaust.
I followed the trouble shooting from the factory manual. The resistance on the dist cap and high tension wires is OK. So is the resistance across the + and - leads in the distributer. The gap/clearance is OK in the distributer and the resistance across the terminals of the plug (the last part of the troubleshooting where you disconnect a plug that is at about 1 o'clock as you are looking at the distributor (from the drivers side)).
The only thing I could not check was for sparks on each plug because the battery was low.
Help...
