Manifold Gasket
I have a 1989 Toyota Camry (4 Cylinder) there is a very bad oil leak on the back side of the engine, passenger side, which I cannot locate. It looks like the leak is somewhere around the intake manifold where it mates with the engine. Is it a possibility that the leak is between the manifold and engine block and the intake manifold gasket needs to be changed? Also when the car is first started there is a small puff of blue smoke, which means oil is in the cylinder. Does this also point to the manifold gasket?
Thanks in advance for any help,
rsnyct
