Originally Posted by dem2757
i dont see why you are concerned when you passes emissions in california...with room to spare too.
what always works without fail, why fix it if it aint broken. changing the timing wont do much expect possibly give a longer and better burn. but really its not worth it unless you failed it, and you said the thing runs fine.
Are you saying I would be changing the timing from normal to abnormal? meaning 10 BTDC is norm for this car and if I went to TDC it would cause problems?
If I can get a better and longer burn would that help with MPG?
I have the time to tinker with this if there are improvements to make, if something can be corrected then I want to spend the time to do it. I put a lot of time into this engine already and want to do whatever I can to make it as right as possible.
EDIT: I just read something about bad gas possibly causing a high HC number. The same 1/2 tank has been sitting in the car for at least over 6 months now and was likely filled with the cheapest gas possible (my nephews drove it) before the head gasket blew. I'll pour some seafoam in the tank and run it out and start using better gas.
