Door dent repair project - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-15-2011, 09:49 AM   #1 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
I started a project to repair a dent on my Camry's door.
A door from the wrecking yard is out of the question due to the following reasons:
  1. Beige wagons are rare
  2. Doors may have damage
  3. The wrecking yard charges extra for hardaware so you will have to buy the sheet metal only
  4. It will have color mismatch and may no seal properly causing leaks
First I pounded the dent with the block of wood and rubber hammer
It looked ugly
Most books for home mechanics are skipping the facts that before filling and painting you should shape the sheet metal using body dollies and special hammer. I made some tools for this purpose trying to copy the curvature of the door
This is how it looked when I knocked the spots down:
and this is how it looks when almost done (note I skipped the some larger but very shallow dents at the molding line)
Priming ,sanding and spot paint are the next steps.
Now I have a questions:
Which spray touch -up paint is the best to use ?
Who sells touch code 3H4 (beige) touch up paint?
Thanks!!!
Doctor J is offline   Reply With Quote
Old 03-15-2011, 11:59 AM   #2 (permalink)
View nopain00's Photo Gallery
Looks good so far. Did you hammer from the outside only or inside too?
I use paintscratch.com. I've found their touch-up is actually more accurate than that from the dealer, and they will put it into an aerosal can for you.
Some tips: the paint they send you matches the original color of your car. Most of the gen2s have oxidized paint by now. To see how different it would look, open any door and look at the inside of the jamb comparing the paint that's never been exposed to sunlight to the paint elsewhere. If it's close, then the factory-code paint will match.
Paint scratch will also match paint chips if you send them in. This is better to match aged paints. I would also recommend painting more than just the region you've primed or else it will look like a blotch. If you don't to paint the whole door, paint the entire area underneath the plastic moulding to get a more even look. You'll need to sand and prime, and of course mask the plastic.
nopain00 is offline   Reply With Quote
Old 03-15-2011, 01:05 PM   #3 (permalink)
Doctor J's Avatar
First I did it from inside out (picture1), then I used hammer with polished flat tip on the outside, with the "dollies" inside.
The paint did not oxidize much
I actually found the website that sells the paint matching the color code.
in the past I used some Rust Oleum premium enamel from Grainger (almond) but it was lighter then the car's paint.
Old 03-15-2011, 02:08 PM   #4 (permalink)
...also, I think 3H4 is red. Do you mean 4H3?
Old 03-15-2011, 03:18 PM   #5 (permalink)
Doctor J's Avatar
4H3
my bad
Old 03-15-2011, 07:25 PM   #6 (permalink)
Just wanted to make sure you didn't end up with a beige Camry with a red door
Old 03-16-2011, 06:20 AM   #7 (permalink)
Tom 2000's Avatar
Gameroom cash: $200700
View Tom 2000's Photo Gallery
I recommend Paintscratch.com also. Several years ago I had to fix the back bumper of my Camry. After the repair, I could not tell anything had even happened.
Tom
2004 Prius Touring Edition
2003 Corolla Luxel
2000 Camry LE - Lunar Mist Metallic
Tom 2000 is offline   Reply With Quote
