Stumble after a big pothole? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-15-2011, 09:04 PM   #1 (permalink)
WhippinCamry's Avatar
View WhippinCamry's Photo Gallery
2nd Generation Stumble after a big pothole?
My car occasionally will stutter/stumble/bog on acceleration occasionally.
no set pattern just randomly. cold or hot. lots and lots of new parts.
including the whole igntion system.
today i hit i big pothole and the car did this really weird. quick misfire/stutter. and then was fine after.
i do have a worn rear motor mount im going to get done after my rear brakes this weekend.
i checked the ground to the tranny and the one my the power steering.
anywhere else?
i read it could be that. but whatever it is. its electrical seems like.
WhippinCamry is offline   Reply With Quote
Old 03-15-2011, 09:18 PM   #2 (permalink)
dem2757's Avatar
Gameroom cash: $274500
View dem2757's Photo Gallery
have you checked the vacuum lines to the fuel rail? i know you replaced the vacuum lines but this one will do something like you are experiencing. other than that maybe you have a cracked wire insulation somewhere in the wiring harness
dem2757 is offline   Reply With Quote
Old 03-15-2011, 09:35 PM   #3 (permalink)
to the fuel rail? hmmm didnt see any there?
the brake booster hoses are new. and yes all easily visable hoses are replaced.
the most hidden one being the egr to egr filter i would say and one below that which i beleive is to the back of the fuel rail.
i know my batterys slanted (the way the mount is) i read someone had there pos terminal hitting the hold down and grounding it out.
ill check grounds tomrw.
could my bogging be a bad fuel injector o ring?
im just at a huge loss with that.
reset the ecu trying to solve some problems. plus i have a cold air intake and dc sports exhaust.
got a little power. had timing advanced 2 degrees and reset it again. cause the gas pedel felt spongier than before. and its never been as peppy as it was the first time i reset it.
Old 03-15-2011, 09:38 PM   #4 (permalink)
heres a list of new parts.
o2 sensor,oil temp sensor (it was leaking a little),fuel filter,air filter,vaccum lines,trans mount,front mount, (rear mount was the actuall bad one lol). new tps,egr cleaned,throttle body cleaned,new gasket on throttle body,new distributor,cap and wires (napa premium plus) denso plugs,valve cover gasket. thats basically it.
Old 03-15-2011, 10:11 PM   #5 (permalink)
dem2757's Avatar
at least on my v6 there are vacuum lines for fuel pressure regulation.
Old 03-15-2011, 10:13 PM   #6 (permalink)
dem2757's Avatar
did you change your air flow meter?
Old 03-16-2011, 12:26 AM   #7 (permalink)
View holmesnmanny's Photo Gallery
Mine did this until I retimed it. It turned out it was 4 degrees ATDC omg!
It needs to be 10 degrees before top dead center. Unless you already did, then just disregard it.
But mine stumbled when cold before being warmed up until I got the timing right.
1991 Camry LE V6 Automatic
holmesnmanny is offline   Reply With Quote
Old 03-16-2011, 08:01 AM   #8 (permalink)
its timed 2 degrees advance from 10.
i timed it by ear. then took it to a shop and they said it was dead on 10.
i got good ears apparently or good luck.
the air flow meter no havent checked really. might just replace with one from the junkyard. could be my problem i suppose.
