So, my questions:
- Could the power steering fluid be causing or exacerbating my leak?
- Should I flush & replace?
- Am I screwed?
question 1 you've answered,
yes you should replace the fluid to what toyota recommends. I kind of doubt you damaged anything by adding PS fluid instead of the recommended ATF but i'd get it out of there as soon as i could anyway.
You're replacing the hose so most of your fluid is just going to drain out into your waste container (insert boilerplate fluid-disposal warning here). That will take out most of the PS fluid.
Flush it? yes, i would, lazy man's method 1: When you reattach everything top up with the recomended fluid. Then run the engine one or two minutes, shut off. Suck reservoir dry with a turkey baster, refill, run it for a minute, like that 3 or 4 times. That's the lazy way and probably good enough (for me anyway).
The thorough way is while you have a hose removed, run the engine and keep adding fluid. You'll definitely need a helper, to shut off the engine before the pump runs dry (which will happen fast). if no helper is available may i suggest method 1.
