Constant loss of power on camry 1990 2.0 dlx
Hi guys! I need your advice. I can't figure out what is going on with my car. It climbs uphill with no more than 40 mph, and it takes so much time to speed up on the highway. I changed spark plugs, fuel filter, air filter, put new cat converter, put new coolant temperature sensor, cleaned throttle body with special spray, cleaned air mass meter with spray. I'm not a car pro, but to me it looks like it's not a electrical(wires, distributor or smth) problem.
Car has new starter and battery, starts every time(except when its 0-10 degrees outside,)
Fuel mileage for 2.0 car is horrible. On 13.5 gal full tank it made 300 miles.
Also a bit weird thing. In camry manual I read about resistance specifications for air mass meter between terminals VC-E2 should be 3000-7000 Ohms, but I read about 280 Ohms. I even went to a junk yard and measured 4 or 5 camrys, the same thing - 280. All 5 mass meters are bad? Any ideas?
When I connected TE1 and E1 terminals computer showed no error codes.
When I connected +B and FP terminals(to check fuel pump operation), I heard fuel going thru lines, like it should be(I didn't checked pressure though).
And also, does anybody know where is ECU connection?
Thank you.
