FM radio reception poor in 1991 camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-29-2011, 08:08 PM   #1 (permalink)
View trickytiger's Photo Gallery
Hi,
Just wondering if anyone can help give me some ideas for my fm reception problem.
First off I have installed an aftermarket JVC headunit into my 1991 camry, took out the band expander that was behind the factory stereo but fm reception is still poor and the radio stations are on the wrong frequencies.
Question 1: Where is the internal antenna located?
Question 2: Any ideas on where another band expander may of been installed, if someone has put more than one in?
trickytiger is offline   Reply With Quote
Old 03-30-2011, 07:19 PM   #2 (permalink)
WhippinCamry's Avatar
View WhippinCamry's Photo Gallery
Yes i would like to know this too. my favorite station comes in very blurry and its just in my car. and i have a aftermarket pioneer deck.
WhippinCamry is offline   Reply With Quote
Old 03-31-2011, 12:54 AM   #3 (permalink)
I appear to have fixed the fm reception problem in my car, if i find it's definitely fixed i'll reply with the fix.
Old 03-31-2011, 03:57 AM   #4 (permalink)
thank you!
Old 03-31-2011, 05:22 PM   #5 (permalink)
ok, I can confirm my problem is now fixed as I can pick up radio stations now and keep them while driving just a bit of static on them but that can be fixed with a bit more work.
Here is what I done, I found out that the aerial cable from the stereo goes into a small box behind the panel at the left of the rear window and then clips into the rear window.
To fix: take of the panel at the left of the rear window (this is just clipped on) then you will find a steel cover with wires going in and out of it, take the 10mm bolt off and unscrew it. Then you need to take the 2 screws by the wires out of the box (don't bother putting these back in as they seem to interfere with the reception). then you just tape the box up so that there is no bare steel showing.
After you have done this put the box back in it's hole (the steel part the 10mm bolt went into needs taped up also, you won't need it bolted anyway.) then put the steel cover back on and screw it on.
Old 04-01-2011, 02:44 PM   #6 (permalink)
I know it might seem like a pain sence you already did it. but where is this metal box? im having a hard time figuring out where it is.
Old 04-04-2011, 12:34 AM   #7 (permalink)
If you pop the panel off at the left side of your rear window you'll find it
I'll post some pics up when it's sunny if ou haven't found it by then
Old 04-04-2011, 01:12 AM   #8 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
Where is the antenna on your car? I've never heard about this box before.
On most US gen2 Camrys, the antenna is in the driver's side A-pillar, so there is no reason for any radio related stuff to be that far back in the car. I haven't traced the antenna wire on my LE model yet though (rear quarter panel auto antenna).
-Charlie
Old 04-04-2011, 01:08 PM   #9 (permalink)
View nopain00's Photo Gallery
With the rear power antennae, there is wiring that goes to the back and runs down the C pillar. According to the parts diagrams, there are some that have a rear-window antenna. There might be a metal box there. Trickytiger: do you have a sedan or a wagon?
nopain00 is offline   Reply With Quote
Old 04-06-2011, 11:11 PM   #10 (permalink)
I have the 91 Camry Prominent Sedan which has the rear-window antenna, which also has a metal box there.
