The light failure sensor thinks the center tail light bulb is out since the LED light draws less current.
You can replace all the brake light bulbs with the exact same bulbs from the store, or (cheaper) you can try switching the bulbs around to see if you just have one bright one. As for the grounds, remove them, clean them (sandpaper) and put them all back. Also check the metal reflectors to make sure they are clean.
I actually have one slightly brighter tail light on my Alltrac, but it is because one of the 4 sections is an replacement part (not sure if it is just newer OEM or what).
Let us know what you find.
-Charlie
