Struts - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-02-2011, 09:13 PM   #1 (permalink)
dem2757's Avatar
Gameroom cash: $274500
View dem2757's Photo Gallery
Struts
Alright, im about to do the struts on the camry, would these from rock auto be the best bet?
Monroe OE Spectrum
dem2757 is offline   Reply With Quote
Old 04-03-2011, 09:10 AM   #2 (permalink)
Gameroom cash: $128800
View Sturdavj's Photo Gallery
I placed these (Monroe) on the front of my 90' Camry. On the rear I am considering using KYB gas shocks. Only because I found the KYB after I installed the front struts.
Both are quality products
Sturdavj is offline   Reply With Quote
Old 04-03-2011, 10:29 AM   #3 (permalink)
dem2757's Avatar
okay thanks! im gonna snap these up quick they are on sale
ill hopefully be posting a DIY on the forum. In addition to the 2 others here
Old 04-03-2011, 11:19 AM   #4 (permalink)
The trick is to use “Quality” spring compressors. When I did my last set with a pair of hand- me- off’s I have used for years, they slipped , I got PO and dropped them on the ground, the bottom nut then stripped out.
Needless to say they were ready to let loose.
Be sure your compressors are safe. I plan to rent a set (Quality) the next time..
You may want to check on the cost of mounting plates, I picked mine up the same time as the struts. I probably did not to R&R the old ones but because I was in there I choose to “get Er’ done”
Old 04-03-2011, 11:26 AM   #5 (permalink)
dem2757's Avatar
ah yes...i know the dangers of the spring compressors. sorry to hear about your bad experience! we plan on using the thicker made, heavy hooked ones. the autozone spin type is known to suck, and break.
i am buying new mounts, struts and spring rubber boots to prevent the metal on metal contact. i want the piston shields too.
im getting the clunking anyways when i go over bumps. its either the mounts, or my sway bar is rattling in the wallowed bushings. either way, the suspension will be mainly new
Old 04-03-2011, 11:50 AM   #6 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
Don't forget bump rubbers too.
And yes, the springs on this car need to be heavily compressed for removal. A quality compressor is important.
On my Subaru, you can just undo the top nut and everything falls apart (even with stock springs). To assemble, it takes the weight of one person to re-compress enough to assemble.
-Charlie
Old 04-03-2011, 11:50 AM   #7 (permalink)
Your ahead of me, my rear links are shot they need R&R. I did my fronts struts, was planning on doing the rear the next pay-period, the auto transmission went TU. I picked up a replacement, pulled the engine and I am finishing up replacing all the rubber parts. My wiring loom was pretty sad so re-wrapped it last night with http://www.google.com/products/catal...d=0CD8Q8wIwBA# man I love this stuff, I use rolls of it on everything. I use it at work on our high voltage systems
Old 04-03-2011, 08:07 PM   #8 (permalink)
dem2757's Avatar
my shocks are so low resistances that i can just sit on the rear of the car and attach the compressor and presto!
im sure its gonna need some more compressing but when i have 2 people in the back ( 300-350 lbs combined) the springs are almost touching
Old 04-04-2011, 07:41 AM   #9 (permalink)
Tom 2000's Avatar
Gameroom cash: $200700
View Tom 2000's Photo Gallery
First couple of times I replaced struts, I used cheap spring compressors from harbor freight. They worked, but you get what you pay for. I bought some nice spring compressors from Sears after that. Cost a lot more, but they were built very sturdy, easier to use and replaced 3 more sets of struts since then and still work like new.
The right tools make all the difference. I am actually looking forward to the next strut job.
Tom
2004 Prius Touring Edition
2003 Corolla Luxel
2000 Camry LE - Lunar Mist Metallic
Tom 2000 is offline   Reply With Quote
Old 04-05-2011, 10:37 AM   #10 (permalink)
dem2757's Avatar
ah i love sears. ill be sure to check theirs out
Old 04-05-2011, 01:11 PM   #11 (permalink)
Which Sears part # ? for spring compressors
