For the temp gauge on the gauge cluster, you are looking for a single wire connector on the water outlet neck. Check the wiring around there, and adjust/move all the connectors to loosen any corrosion.
If you want to try a new sender, make sure you buy the "Water Temp Sender" not the "Water Temp Sensor" (sender = gauge cluster, sensor = ECU).
-Charlie
