Inner Tie Rod 91 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-08-2011, 01:00 PM   #1 (permalink)
View ivegottheblues's Photo Gallery
Hi all,
I've been searching the forums looking for a good post on replacing the inner tie rod end. I couldn't find anything concrete.
Does anyone have a good method for doing this?
Anything is appreicated, thanks.
ivegottheblues is offline   Reply With Quote
Old 04-08-2011, 01:59 PM   #2 (permalink)
Gameroom cash: $163200
View Grego 92's Photo Gallery
I did do this recently but I don't have a write up. Here's a link to some pictures.
Low Rumbling Noise
I followed the manual to remove the outer tie rod (needed one of those tie rod pullers). then removed the boot/bellow, then used a crow bar and hammer to straighten the washers, then used the harbor freight inner tie rod removal tool.
When I put it back together I didn't know how to bend the new washer, so I just used some loc-tite on the threading like I read somewhere previously.
Grego 92 is offline   Reply With Quote
The Following User Says Thank You to Grego 92 For This Useful Post:
ivegottheblues (04-08-2011)
Old 04-08-2011, 05:15 PM   #3 (permalink)
Thanks. That post helped a lot.
I'll post an update tonight when I finish.
Old 04-10-2011, 11:05 AM   #4 (permalink)
Gameroom cash: $128800
View Sturdavj's Photo Gallery
There is no inner tie rod end. There is a tied rod with a ball & socket on the inner end. This is replaced as a unit.
1. Pull back the rubber boot and secure with a tie-wrap
2. Use a long drift punch/screw driver/pry bar and straighten out the “bent lock washer tabs”
3. I then used a 10” & 12” adjustable wrench(s) to remove the tie-rod unit. Place one wrench on the steering actuator and the other on tie-rod nut.
4. Installation process is the reverse of removal.
5. Be sure to bend the locking tabs back, new ones usually come w/tie-rod assembly. This is a steering component and while I am a big proponent of loc-tight, I would not bypass a mechanical lock on steering components
Sturdavj is offline   Reply With Quote
Old 04-11-2011, 12:11 PM   #5 (permalink)
Any trick to bending the washer back? From above or bottom any easier?
Old 04-11-2011, 12:19 PM   #6 (permalink)
I accessed mine from the bottom, I used a long (14-16 inch shaft) and a small ball peen hammer. Once it starts to bend, it will go easy.
I don't recall if I had my cross memeber off at the time. I had it on / off a couple of times. I own a number of air tools, so it is/was easy for me to drop the X-member.
I still beleive it's best from below.
