Quick Question regarding servicable strut - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-12-2011, 03:17 AM   #1 (permalink)
View Kingdom934's Photo Gallery
So I'm working on my passenger side of my Gen1 now (finally got the driver side taken care of).
This side, the strut is dead (figure). Since my driver side was half done from age, this side spanner nut (the nut that holds the cartridge) is not budging! I've tried using a chisel...well I'm actually digging through the nut (I've been pb blasting it). I've heard of a spanner/shifter....54mm I believe. I can't seem to find it online at a local mainchain store (sears). Is there another name for this?
Thanks!
'85 Camry DLX 158K
'87 Cressida 78K
'07 Nissan Versa 63K SD (traded in)
'10 Nissan Versa 26K HB (traded in)
'04 Camry XLE V6 52
Kingdom934 is offline   Reply With Quote
Old 04-12-2011, 07:39 AM   #2 (permalink)
セクシーの定義
Gameroom cash: $117610
View Jimnist's Photo Gallery
Not that i know of. You can try using multi-grips, but beware! You could chew off the edges and truly screw yourself.
I'd just get a bigger hammer and soak it more. Are you hitting it on a good angle? If you can't undo them, you could always buy aftermarket non-serviceable ones.
Personally, I'd prefer those - far less hassle. With the serviceable ones, you can't have it too tight as you might snap the welds and too loose means they'll vibrate loose. The latter has happened which resulted in some sketchy handling.
I think the only way to stop them from undoing is to safety lockwire them, but it seems like such an overkill.
Camry history:
1990 Camry CS 5spd - Now scrap metal
1994 Camry Executive A/T - Burnt to a crisp.
1995 Camry Vienta Csi A/T - Still running
1999 Camry Touring 5 spd - Current
Jimnist is offline   Reply With Quote
Old 04-12-2011, 11:06 AM   #3 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
I used a pipe wrench both times I have done serviceable struts... if the gland nut is really stuck on there though, that might not work.
Good luck!
-Charlie
The Following User Says Thank You to white90dx For This Useful Post:
Kingdom934 (04-13-2011)
Old 04-12-2011, 12:39 PM   #4 (permalink)
Alrighty.
I'll try soak it...more. With regards to serviceable vs nonservicable, I wish there was nonservicable ones for the Gen1...I would avoid this if I could haha.
I'll try see if I got a pipe wrech.
'85 Camry DLX 158K
'87 Cressida 78K
'04 Camry XLE V6 52
Old 04-13-2011, 01:25 AM   #5 (permalink)
i got a pipe wrench and it was off less then a minute...
So I had the entire assemb out. I had only the strut housing and the strut itself (springs off) attaached to the car since I needed leverage. Got a 14" pipe wrench, had it on and a few hammers, it came off.
Got entire front i nback together and the car drives like a dream....now gotta do rears >.<
'85 Camry DLX 158K
'87 Cressida 78K
'04 Camry XLE V6 52
Old 04-13-2011, 11:09 AM   #6 (permalink)
white90dx's Avatar
Awesome. I don't really like the idea of using plumbing tools on my car, but in this case it works pretty well.
The 'correct' way to hold the strut is with a vice on a bench top. I did that one time, the other time, I think I jammed something through the lower mounting holes to keep things from spinning. (both times off the car)
Hopefully this helps somebody else too.
-Charlie
Old 04-13-2011, 02:11 PM   #7 (permalink)
-Charlie
Haha. It works.
I know, the correct way was to get a vice grip but blah...I don't got a vice grip or a good table (no use in having a table break, right?).
Good info...who'd thought of a pipe wrench, lol. Now I can work on my serviceable struts and my kitchen sink
'85 Camry DLX 158K
'87 Cressida 78K
'04 Camry XLE V6 52
