Stop leak - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-12-2011, 07:08 PM   #1 (permalink)
View bellysoldier's Photo Gallery
Stop leak
My 89 Camry's Differential is leaking.
There are some kind of products such as Bar's stop leak, White Shepherd transmission sealer in the market.
Does this product work ? Thanks
bellysoldier is offline   Reply With Quote
Old 04-13-2011, 10:23 AM   #2 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $160315
View 96paseo's Photo Gallery
You can try but I highly doubt its gonna stop your leak. Bad output shaft seals are likely the problem. You need to pull the hub and driveshafts to replace them.
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 249,xxx miles - New water pump, TB etc etc
1989 Camry-Gone but not forgotten. Car has become a birthday gift for my cousin.
1997 Mazda B2300 213,xxx miles - New flasher relay installed.
96paseo is offline   Reply With Quote
Old 04-13-2011, 12:56 PM   #3 (permalink)
The mechanic told me that it will cost me high to fix it. I used 1500 dollars to buy this car. If this kind of product works it will be good. Now it is leaking not serioursly. I am afraid of this product that maybe make the problem worst.
Old 04-13-2011, 06:18 PM   #4 (permalink)
Gameroom cash: $285600
View '88 All-Trac's Photo Gallery
Is this an auto or a manual? Dump in some Lucas oil stabilizer if it's a manual. Stopped the leaks in my brother's '94 Celica trans.
The shaft seals are not hard to do... Just a couple of hours your first time.
'88 All-Trac is offline   Reply With Quote
Old 04-14-2011, 01:14 PM   #5 (permalink)
AnimatedMechanic's Avatar
View AnimatedMechanic's Photo Gallery
I would suggest Gold Eagle Transmission Stop Leak. It has worked great for me in the past.
2009 Toyota Venza V6 FWD
1991 Toyota Camry V6 LE
1987 Toyota Camry LE
1989 Toyota Camry Base (Retired)
1993 Ford F-350 XLT 4WD Lifted
AnimatedMechanic is offline   Reply With Quote
