2SE distributor going bad? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-19-2011, 03:00 PM   #1 (permalink)
View md303's Photo Gallery
Hi, I have a 1984 Camry DLX with the 2SELC engine. Over time, I have had to re-adjust my ignition timing several times to keep it in spec, and I don't understand why. As of now, the distributor is clocked CCW as far as it will go, and while the timing is correct again, I fear it will go out of spec again.
Anyone know what can cause this? I am at a loss, it's not like the distributor is a very complicated device...
Thanks!
md303 is offline   Reply With Quote
Old 04-19-2011, 11:08 PM   #2 (permalink)
71Corolla's Avatar
Gameroom cash: $548250
View 71Corolla's Photo Gallery
Your distributor uses weights and a vacuum advance, is this right? It's possible the springs inside the distributor are becoming weak.
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
71Corolla is online now   Reply With Quote
Old 04-22-2011, 12:51 PM   #3 (permalink)
Yes, it uses weights and vacuum advance. So what do the weights/springs actually do? Retard timing as engine RPM increases, while vacuum advances it?
Old 04-22-2011, 09:26 PM   #4 (permalink)
View nopain00's Photo Gallery
Not quite. Both advance the timing.
Basically the weights are held in by the springs, but at fast engine speeds, centrifugal force spins them outward, which turn the top of the distributor in such a way to advance timing. Vacuum advance is to advance timing additionally, especially at partially open throttle positions. In those cases, the engine pulls a large vacuum, resulting in only a small amount of air and fuel, which would not burn efficiently if it were only for the centrifugal weights. Thus, based on engine load (i.e. the vacuum), the distributor is advanced to allow for ideal combustion.
Now back to your original question. Are you saying that your timing keeps advancing, and you need to keep turning the distributor to retard it, or is it the other way around.
You should be checking timing at idle, without any advance. If the springs are weak, they would advance too early and you would get the problem you are describing. If the weights are stuck, you wouldn't see a problem at idle, but you would have a lot less power at WOT.
Another possibility is that your timing belt is off. If it's off a tooth, then it's possible that your distributor would be off, but it would be constantly off by the same amount. You wouldn't get it constantly changing the way you are describing.
Take a look at the weights and springs. I don't know whether you can get those parts separately for your car. You can try swapping the cap for another one to see whether it's any better, or getting a new one all together.
nopain00 is offline   Reply With Quote
Old 04-23-2011, 05:45 PM   #5 (permalink)
Gameroom cash: $303055
One other thing that can go wrong with these distributors is the bearing inside the distributor shaft itself can wear out. This is easy to check. Remove the distributor cap and grsab hold of the rotor and try to rotate it side to side. There should be virtually no side to side rotation. If there is, the bearings are worn and the distributor needs to be replaced.
Mike
