Control Arms Replacement - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-19-2011, 03:20 PM   #1 (permalink)
Gameroom cash: $163200
View Grego 92's Photo Gallery
2nd Generation Control Arms Replacement
I'm in the middle of doing this task. I ordered a "pair" w/balljoints included from ebay but was sent two that were both stamped "R" and I can tell the angles are the same, whereas the ones I removed are angled opposite and stamped "L" and "R". (I swear I tell myself to order from toyotapartszone or my neighborhood auto store but never listen to myself!) So, I'm waiting/hoping the guy sends me a "Left" and makes good.
My Balljoints were gone and all the bushings were either torn or mushy.
Anyhow, I have it all apart and kept on reading posts and came across this from Doctor J.
Originally Posted by Doctor J View Post
FRED:
The caster shims are flat washers about 1 inch OD, 1/8 inch thick are located on the front sway bar in front of lower control arm big bushing.
Page FA 60 in Gen second manual Front end section.
NURON, my arms are the same but ball joints do not have boss on the top. Check the suspension for play as I suggested.
If there is no play ,make sure that you have shims at specified locations, and set camber cams on center position. If there is no shims, put washers 1/8 in thk (material steel SAE 1040).From this setting the front end could be aligned with ease.
Link to entire thread Just give me an alignment...
Is he referring to what I have pictured below circled in RED? Because I noticed I don't have those either. Do you need them to align correctly?
I do have the retainers that seemed to be made of plastic and a big ol' "cupped" metal washer inside of that.
1990 Camry LE v6
1992 Pickup Dlx 4x4 4cyl.
2005 Nissan Frontier 4x4 Nismo v6
Grego 92 is offline   Reply With Quote
Old 04-19-2011, 11:15 PM   #2 (permalink)
71Corolla's Avatar
Gameroom cash: $548250
View 71Corolla's Photo Gallery
If your car did not have the spacers originally, they you don't need them. I don't think the alignment is dependent on the sway bar so you don't have to worry about that aspect.
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
71Corolla is online now   Reply With Quote
Old 04-20-2011, 12:41 AM   #3 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $406595
View atobe's Photo Gallery
the affects the caster a little bit but shouldn't do much harm. i don't think i have that spacer either so no worries
Old 04-20-2011, 10:53 AM   #4 (permalink)
Good to hear I may not need them. I just don't know if they were on there before (not original owner) and some mechanic took them off in order to attempt to align the vehicle properly to compensate for the bad bushings in the LCAs, the destroyed struts, or the bad inner and outer tie rod.
I typed my vin into the yotapartszone site and they came up as parts to my vehicle so I ordered them since they weren't much and I was ordering something else anyhow.
1990 Camry LE v6
