prius rims? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-27-2011, 10:21 PM   #1 (permalink)
ecl
View ecl's Photo Gallery
prius rims?
Im looking to get some different rims and figured since im trying to squeeze as many mugs as possible I figured I would look into lighter rims. I've been trying to see if a prius rims would fit. From what I can tell the bolt pattern is 5x100 for the camry but im seeing 4x100 for the prius which I know isn't right since the the prius is a 5 lug pattern. Any help would be great thanks.
ecl is offline   Reply With Quote
Old 04-27-2011, 10:44 PM   #2 (permalink)
Gameroom cash: $285600
View '88 All-Trac's Photo Gallery
http://www.vehicle-bolt-pattern.com/...nce-guide.html
http://www.discountedwheelwarehouse...._Reference.cfm
http://priuschat.com/forums/gen-ii-p...t-prius-2.html
Looks like Prius is a 5x100mm setup, just like our beloved Gen 2 Camrys.
'88 All-Trac is offline   Reply With Quote
Old 04-28-2011, 12:19 PM   #3 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
It looks like the offset is a bit high, so the wheels will look a bit sunken-in on the car (especially the rear). The hub bore is the same, at least... Scion tC 17's will fit the same way (correct bolt pattern and hub bore, high offset).
You can also get wheels from any 5-lug FWD or AWD Celica - they also fit without modification and generally have a better offset.
-Charlie
