I've broken the BVSV too when working on my dizzy. As Doctor J said, the charcoal canister stores fuel vapors from the gas tank. When the engine gets to running temperature, this valve opens and the hydrocarbons from the canister are absorbed and burned, preventing release of HC to the environment.
If you leave it broken, you do have a vacuum leak. if you connect the hoses together you get rid of this problem. I'm not sure exactly what will happen to the charcoal canister over time if you simply leave it disconnected. It will continue filling with liquid and gaseous hydrocarbons. I assume that over time it will reach a maximum pressure and not absorb any more, which will increase pressure in your fuel tank as well. Over a certain pressure, it will release the fuel vapors and liquid to the environment.
I swapped my broken one for one from a junked car for <$20. They are interchangeable among many of the cars from the 90s. If you search ebay, you'll come up with a lot of hits. Pick-and-pull type yards will be even cheaper.
