91 vs 92 rear wheel bearing hub/axle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-04-2011, 03:28 PM   #1 (permalink)
View bpe383's Photo Gallery
Will a hub/spindle unit (spindle being the part with the studs) from a 92 fit a 91 camry? If the difference is ABS ring on the back, can I put one with the abs ring on the no abs equipped car? I understand it will serve no function which is fine, just need to know if the spacing is ok, and if there are any differences in the overall depth, and if the braking system also makes a difference.
bpe383 is offline   Reply With Quote
Old 05-04-2011, 03:44 PM   #2 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
The '92 and '91 rear hubs have different bolt patterns, center bore and strut mounting tabs, at the very least. (the only way this would work is if you were in certain secondary markets where the '92 Camry was still a gen2)
-Charlie
Old 05-04-2011, 10:45 PM   #3 (permalink)
OK will the pic in the link below fit a 91 without abs? It's listed for 91 to 2000 with abs, and the only thing I can tell/see from a pic. is the abs ring. If the abs ring will clear then it should fit a 91 without abs yes? Of course the abs ring will just be dead weight, but not hurt anything.
If not, in short I need what is in the pic, only fitting a 91 camry 2.0 Any ideas?
Thank you
http://shop.advanceautoparts.com/wcs...9_pri_detl.jpg
Old 05-04-2011, 11:09 PM   #4 (permalink)
CRESSIDA!!!
84Cressida's Avatar
Gameroom cash: $654020
View 84Cressida's Photo Gallery
It may be listed for 91-2000, but it's obvious they mean '92-'01, which is the 3rd and 4th gen. '91 Gen 2 is an entirely different beast.
1994 Toyota Pickup Xtra cab 4x2 22R-E 44,000 mi
1998 Toyota Avalon 1MZ-FE 137,000 mi
2005 Chevrolet Silverado Crew Cab 49,000 mi
2006 BMW 330i Sedan 85,000 mi
2007 Toyota Camry Hybrid 2AZ-FXE 62,000 mi
As of May 17, 2011. DEATH TO SCION!
84Cressida is offline   Reply With Quote
